I have one on a 300 and it works pretty well but it has to be plugged in at least two hours ahead to do any good at all, longer is better. I would think that you would need more time on a SMTA since they have so much more engine to heat. A tank heater plumbed into the block is faster to heat and has a much bigger element, but it is more expensive and uglier, and more of a risk of catching on tree branches or such if you use your tractor in the brush or woods. Zach
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
