I have seen lower rad hose heaters on some old tractors. you should be able to install a circulating block htr. also. I have seen them installed in the heat guage port and then to the block drain on the left side. basically you need to pull the cold coolant from bottom of block then push it to the top somewhere on the head. and also a circulating htr. works quite well and quickly. in an hr you will notice big difference.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
