1. Carefully remove the fuel lines that attach to the sediment bowl. Carefully remove sediment bowl from gas tank.
2. Completely drain the gas tank , rinse with warm water to flush out rust particles. Blow dry with compressed air, pay particular attention the the area forward of the large baffle partition.
3. Replace wire mesh & cork gasket at top of sediment bowl.
4. Carefully remove fuel line at carb, remove base fitting & replace wire mesh screen at fitting.
5. use compressed air & blow fuel line out from carb to sediment bowl. Re attach fuel line to sediment bowl & carb.
6. Turn gas off at sediment bowl & place 3 gallons of fresh gas into cleaned fuel tank. Or enough to cover sediment bowl stand pipe.
7. Remove forward pipe plug at bottom of fuel bowl on carb, turn gas on at sediment bowl at gas tank & let it run from the drain on carb into large coffee can for 1 - 2 mins. Turn off fuel at sediment bowl.
8. Battery cables may need to be replaced, Currently available 12 volt cables are too small & offer too much resistance to properly operate a 6 volt system. Replace with ought (0) or double ought(00) sized cable from battery to starter mounting bolt and battery to starter switch. Be sure to solder ends on and cover with large shrink wrap to insulate connections from future corrosion.
13. Replace battery & hook positive side of battery to ground attached as close to starter as possible, (mounting bolt) and negative side of battery to start switch.
( Dis-regard the above if converted to 12 volts)
14. Turn the fuel on at the sediment bowl below gas tank and count to 30 slowly, turn the fuel back off. The carb bowl should be full now.
15. Move the throttle lever to only about 1/3 of total throttle posiition.
16. Turn ignition switch on, and check ammeter movement, it should now show discharge of 3 to 7 amps. ( if not start trouble shooting as indicated above)
17. Pull choke rod out, hit starter switch, push choke rod back in as soon as it fires once, or after four revolutions.
Once tractor starts walk around & turn fuel on & let it run at 1/3 throttle for 5 mins to warm up.
If tractor will not fire or start, check points for pitting & reset, clean rotor and rotor cap contact points. Check condenser.
Double, triple check firing order on distributor cap.
If it still will not fire or start, proceed with electrical trouble shooting as mentioned above.
This post was edited by rhtx55 at 11:36:36 11/30/14 7 times.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
