Re: measurements of cub pistons
Posted by t.r.k. on November 30, 2014 at 13:00:55 from (71.31.64.233):
In Reply to: measurements of cub pistons posted by lindsey raddatz on November 30, 2014 at 06:58:53:
Cub piston measures 1-7/16 compression distance.
also has a .6876 piston pin.
compression rings 3/32 wide, oil ring 1/4" wide. But of course the cub rings will work on the cub pistons.
This from 1966 aftermarket(non IHC) parts catalog.
The catalog doesn't have the specs for the ZXB pistons.
Have you checked with Hercano Propulsion for exact replacment oversize pistons? Also, I have had success sleeving the block back to standard and using the old pistons in other engines.
  Upload Photo  Select Gallery Photo  Attach Serial No List
