Re: 656 lost hydraulics suddenly
Posted by Cory Schmidt on November 30, 2014 at 15:39:11 from (64.246.253.30):
In Reply to: 656 lost hydraulics suddenly posted by fixerupper on November 29, 2014 at 18:04:20:
Check the key on the pump gear. If we lose hydraulics on our 706 that is one of the first things we check. Have a couple of clean buckets on hand for the oil. Then strain through a old sheet and put back in (to save money) when done. The gear might of hung up on something causing the grind. Or worse thing I can think of is the pump itself went out.
My guess (just that guess) the coil went out for not starting or the more obvious the "oh no Gas gauge" (out of fuel) and he just made it home.
  Upload Photo  Select Gallery Photo  Attach Serial No List
