Re: Torqueing a helicoil
Posted by CharlieNJ on November 30, 2014 at 16:38:44 from (174.57.216.64):
In Reply to: Torqueing a helicoil posted by CNKS on November 30, 2014 at 14:47:09:
Four years ago we were putting a basket case Farmall A back together when we noticed a head stud coming up as we torqued it. Those studs are 1/2". So, we put a Heli-Coil in. Well, using a hand drill the hole did not go down straight. The top of that long stud was out of line enough that we could not get the gasket on. So, we heated the bottom of the stud till red, and tapped it back in line. Torqued the head to 80 lbs. no problem. There are a lot of hours on that old A since then with no problem. Heli-Coils are plenty strong. Had an old pressure that vibrated three bolts threads out of the pumps head. Heli-Coiled those too, so far so good. So, drill straight!
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
