You's Takes your chances with any PS unit on a 300U or350U. Ours has had a hard life, and is modestly tight but has had no loader on it. It was also carrying around a 3-14 FH plow, and a 8' FH disk much of its life. Check the arms for serious separate movement (hold one, move the other. 1/8" slop might be good measured at the end of the arm) Kook for signs of clean leak tracks in the dirt on both shaft seals, and at the steering head. There is a welch plug near the bottom that can rust out or leak. The steering wheel should have about an inch of movement from straight ahead with a light spring pressure back to center. (this is the torque sensor and is not slop. 1/2 turn is not cool. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
