Re: 460 Stuck Governor
Posted by Hugh McKinney on November 30, 2014 at 19:13:25 from (99.195.78.180):
In Reply to: 460 Stuck Governor posted by randycarl67 on November 28, 2014 at 13:04:43:
I had a similar problem on mine, those various
linkages between the throttle lever and the governor
are very prone to seize up from too much weather,
rust and crud....I actually broke one of them while
moving the throttle, turned out that it had been
welded once before! I would check the linkages that
are directly beneath the battery, particularly to see
that the shaft moves freely in its bushings. Hugh
  Upload Photo  Select Gallery Photo  Attach Serial No List
