Re: IH656 Fire
Posted by fixerupper on December 01, 2014 at 05:15:35 from (100.42.82.100):
In Reply to: IH656 Fire posted by LaurenceA on November 30, 2014 at 19:46:02:
You had fuel and an ignition source. Ignition source could have been the distributor or the arcing from the generator or alternator brushes. The fuel was a gasoline leak. Nothing other than gas is THAT combustible on that tractor. To make a fire trail there had to be a major leak. Why did it start leaking that bad after the tractor was started? There is no fuel pump on a 656 gas that I know of. If there is a fuel pump the leak is after the pump and it quit leaking after the engine died. Just random thoughts.
