Re: super a valves
Posted by Jim Becker on December 01, 2014 at 07:06:16 from (173.84.240.213):
In Reply to: super a valves posted by rray on November 28, 2014 at 11:59:32:
That block should be the one used in the Super C and later Super A, 123 in the Super C, 113 with thicker sleeves in the Super A. Your head gasket is the correct one for an engine with no water pump. There is/was available a thin wall piston/sleeve that was 1/16 overbore from 123 (3-3/16 bore). It appears that may be what you have.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
