Re: F-12 pistons
Posted by 36F30 on December 01, 2014 at 15:48:48 from (63.230.62.211):
In Reply to: F-12 pistons posted by oldiron29 on December 01, 2014 at 13:49:00:
I have a couple extras but they are all the taller ones.
4854DA is the 5,000' kerosene high compression piston, but my book lists 4885D as the pump cover for hydraulic lift.
4835DA is standard kerosene, 4854DA is the 5,000' kero piston, 5623DA are 8,000' non kero pistons, 38739D are 5,000' kero pistons, 39187DA are 8,000' non kero pistons, 5680DX is a 5,000' non kero piston, 5694DX is a 8'000' non kero.
