Re: Alternator wire
Posted by David G on December 01, 2014 at 17:53:52 from (204.12.184.93):
In Reply to: Re: Alternator wire posted by farmall4856 on December 01, 2014 at 17:21:54:
There are alternators in generator shells, you could be right, but they are several hundred dollars each.
Can you take a close picture of the ends and ID tag.
  Upload Photo  Select Gallery Photo  Attach Serial No List
