Re: W400
Posted by Janicholson on December 01, 2014 at 18:27:50 from (74.60.94.18):
In Reply to: W400 posted by kub6040 on December 01, 2014 at 18:11:30:
Spliced axles are those that have had some other axle welded onto the original. Do you mean splined axles with grooves all around? Jim
  • Re: W400 kub6040 19:07:42 12/01/14 (0)
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
