Posted by DR. EVIL on December 02, 2014 at 09:03:37 from (70.194.167.104):
In Reply to: Farmall 350 TA Troubles posted by Andrew Psencik on December 02, 2014 at 06:16:26:
It sounds like the little planet gears are junk. The actual shift into low range is done by a small dry disk clutch releasing & engaging, all gears are already meshing and the clutch directs power thru the proper set of gears.
I would NOT pull the TA lever back until you can get the TA replaced, and those teeth on those planet gears are tiny and fragile, bet some have sheared off, I wouldn't run the tractor much until fixed either.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
