Re: Farmall 350 TA Troubles
Posted by D Slater on December 02, 2014 at 09:56:01 from (184.14.166.249):
In Reply to: Farmall 350 TA Troubles posted by Andrew Psencik on December 02, 2014 at 06:16:26:
May be able to remove the 3 bolt tin cover on center housing top and see if the T/A release bearing, bearing holder, fork and pressure plate fingers are intact or in operational condition as a first step. If you can't see enough through the small hole remove the complete top plate. That will also let you look at the T/A planet gears.
  Upload Photo  Select Gallery Photo  Attach Serial No List
