If it charged for a little we know it can charge. Use the same jumper wire. With it running 3/4 throttle, jump from good ground to the F terminal on the generator. (not dangerous, it just causes it to charge max amps) If it charges when jumpered to ground, the generator is good, and the VR is suspect. If it does not charge with it jumpered, the VR, or the Generator could be at fault. Using a volt meter, (with it running and field grounded) check the volts on the Arm terminal of the Gen. If little or nothing, the generator may be needing a rebuild. If at or more than 7 volts even like 10 volts, the generator is making voltage and I would replace the regulator. New can be bad, (especially if from across the largest ocean) Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
