Re: Partners traactor Model B
Posted by Red Dave on January 08, 2001 at 10:41:42 from (208.165.46.34):
In Reply to: Partners traactor Model B posted by Dutch on January 08, 2001 at 07:30:03:
Dutch, it loks like your "B" is a 1940. Any block from an A, AV, B or BN should bolt up directly with out any trouble. These are known for breaking out on the left side, just under the manifold when the coolant freezes up. Check out local scrap yards, you should not have too much trouble finding a block. If you post your location, someone on here may be able to give you a lead on one in your neck of the woods. I have seen blocks successfully repaired if the break is not too large, sometimes with weld, sometimes with epoxy. You may wish to explore that option too.
Post A Followup
: Re: Re: Partners traactor Model B
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
