Not much can be done and still avoid brealing the hydraulic system. If you refer to the hitch, a larger diameter cylinder can be installed to increase its lift power with no consequence to the hydraulic system, but with the potential of bending the hitch components. Use the area of the piston to assess the increase in lifting power. A=R*R*Pi I would be cautious to limit the increase to 30% or so above original size. If the tractor pump is worn, the replacement of the pump might fix the issue. Flow rating the system should be a consideration to be sure you are fixing the problem and not a symptom. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
