Re: head gasket for c113 vs c123
Posted by rustred on December 06, 2014 at 13:12:41 from (74.214.152.80):
In Reply to: Re: head gasket for c113 vs c123 posted by rray on December 06, 2014 at 12:25:15:
fire ring is the ring of metal crimped around the cyl. bore on the gasket. I just looked at the pic's and it appears to me as this new gasket is good and the old one not good, or was incorrect. this new gasket should give you a bit more compression also, as its making the combustion area smaller.
as for the reaming of guides don't know size as its machine shop work. once guides are installed valves and seats MUST be ground or replaced accordingly and valve stems measured for wear also, and all the other stuff that goes with it. but maybe you are a machinist and doing the job.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
