Re: Boosting Hydraulic pressure
Posted by IH fan on December 07, 2014 at 12:27:31 from (68.102.228.127):
In Reply to: Boosting Hydraulic pressure posted by mikesbailey on December 06, 2014 at 12:07:16:
mikesbailey said: (quoted from post at 15:07:16 12/06/14) I have a 53 C. with a custom 3 point, It does fairly well with most implements but I would like to know is there a way to boost the hydraulic pressure so that the lifting capacity of the lift.
If yours is the type that lifts with the Touch Control arms, you might be able to fabricate a rod or add a rod so you can lift with both sides of the Touch Control. Of course you would have to move both levers together for this to work, but it could be done.
This should about double the lifting power, but you might also break something along the way... if there is a weak point, you just might find it.
This post was edited by IH fan at 12:28:01 12/07/14.
