Re: Draining and refilling belly pump oil on Farmall H
Posted by Janicholson on December 07, 2014 at 16:56:31 from (74.60.94.18):
In Reply to: Draining and refilling belly pump oil on Farmall H posted by Old Man Grizz on December 07, 2014 at 16:50:22:
There is a pipe plug in the bottom of the casting (sticking down under the tractor) remove it and the oil drains. Put in 6 quarts of Hytran, or 20wt non detergent (if you are staying original and do not mix your fluid with other tractors with Hytran. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
