Re: M carburetor installation
Posted by Lucas0522 on December 07, 2014 at 20:04:05 from (72.37.244.108):
In Reply to: M carburetor installation posted by animal on December 07, 2014 at 19:17:27:
Similar experiences. Normally just put one finger down the hole to operate the throttle butterfly to line it up with the governor prong while I maneuver it into place.
The only thing that comes to mind would be to remove the studs on the manifold so you don't have to maneuver around them while you line up the governor.
