Re: Another question for dieseltech or others
Posted by Owen Aaland on December 07, 2014 at 23:42:32 from (216.47.34.37):
In Reply to: Another question for dieseltech or others posted by Seeing Red on December 07, 2014 at 09:32:40:
Yes it can be done without removing the pump from the tractor but Pete has pretty well described what you may well run into for problems.
It is not so simple as just removing the screws and lifting off the head. The side cover has to come off and the throttle linkage disassembled. It can be a bit tricky to get everything back together again in the correct position. I have done it a few times but it is not a job I would recommend to someone who has not worked on one of those pumps.
