Re: 460 fats hitch hydraulics
Posted by mkirsch on December 08, 2014 at 05:23:07 from (72.45.143.81):
In Reply to: 460 fats hitch hydraulics posted by bmagee on December 07, 2014 at 15:34:12:
How many levers on the side of the hood? One, two or three?
From the factory, a 460 would come with a special "Tel-a-depth" valve to control the fast hitch in the 3rd position. There would be a bunch of linkages running from the hitch, up along under the platform, to the side of the steering pedestal, and to the Tel-a-depth valve.
If you didn't get those parts any regular valve will work fine. Just hook the cylinder hoses to whichever pair of ports corresponds to the lever that you want to use for the fast hitch. If the ports are under the gas tank, just use longer hoses to reach, and tuck them somewhere out of the way with zip ties.
IIRC, the left lever corresponds to the ports on the left, the right/middle lever corresponds to those on the right, and the third lever would either be the fast hitch or the ports on the rear.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
