Re: mmanley,paulfromMI,kub6040,DeltaRed,NebraskaKirk, BobM,Janic
Posted by Cory Schmidt on December 09, 2014 at 16:27:02 from (64.246.253.30):
In Reply to: mmanley,paulfromMI,kub6040,DeltaRed,NebraskaKirk, BobM,Janic posted by kelly in tx on December 09, 2014 at 16:10:37:
take the head to a motor machining shop and have them grind/ clean it and valves and seats, might also want to take the block and crank in to and have them clean and check them to. A little rust is no reason for a whole "new" engine. The pistons are called Fire Crater pistons if I recall, helps with cutting fuel usage I believe. Yes tearing tractors and engines apart then putting back together can be a hassle to get at everything and not forgetting parts.
  Upload Photo  Select Gallery Photo  Attach Serial No List
