Sounds like Fire Crater Pistons. If they turn out OK, they are good. Before getting too deep into making it turn over, the following check should be made: Using 200 grit carbide paper, clean the top 2 inches of the 2 cylinders with the pistons down farthest. After cleaning them up to metal, feel the area about 1/2" down the cylinder wall. if you can feel a distinct ridge, catching it with your finger nail on the way up, it is probably time to actually measure something. You can have a machinist, or good auto technition (or a lending rental shop) use a bore gauge and micrometer to measure the wear. .008 would be my very top limit between the measurement at the very top (no wear) and the top ring stopping point (just below the ridge). That is a diameter measurement, not a radius. If at or more, the sleeves need to come out and a "kit" used to replace them. The Kit will include new pistons, rings, and dry sleeves for the block. It is a rebuild to new type solution. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
