Re: Trying to Start Farmall H
Posted by Cory Schmidt on December 09, 2014 at 17:22:54 from (64.246.253.30):
In Reply to: Re: Trying to Start Farmall H posted by Chris S. on December 09, 2014 at 16:33:49:
Cylinders are numbered 1234 from front of tractor/engine to the back. Take the cap off and crank the tractor over a bit to see what way the rotor turns. Then get Cylinder 1 to Top Dead center(marks on crank pulley) on compression stroke(take out plug when you hear/feel pressure it's on compression). place cap on so rotor points at (or as close as you can)to the "1" on the cap. hook up the wires starting with plug/cylinder 1 at that 1 in direction of rotation follow with 3,4 finish with 2. Get tractor running and slightly twist distributor till running as best as possible.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
