Re: Farmall M two-way hydro set-up
Posted by Janicholson on December 09, 2014 at 19:48:20 from (74.60.94.18):
In Reply to: Farmall M two-way hydro set-up posted by Mongo6318 on December 09, 2014 at 19:00:49:
third party image
third party image
The hoses should be 1/2" usually with NPT fittings. Use only heavy pipe fittings, not plumbing fittings, as they are not rated for pressure and can burst. Each hose should be reinforced Hydraulic system rated (1500 PSI is about twice the pump output for a belly pump) 2500 is about 2X for an engine mounted live system. Each hose needs to have a swivel fitting on one end to allow disconnect and tightening. (means that the fitting can be turned to attach the hose without twisting the hose. I have attached 2 diagrams One for a belly pump (which should have its return into the drain) and one for an engine mounted live system. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
