Posted by The tractor vet on December 09, 2014 at 20:49:49 from (104.179.81.68):
In Reply to: 3 pt hitch on 806 posted by pdaniels on December 08, 2014 at 15:50:41:
If the three point does not go down till it leaks down then the draft sensing is the problem and like delta red told ya remove the top link plate and look in on the right side and you will see and arm-lever coming up from the bottom and you will see a arm - lever hanging downfrom the top . If the top one is inft. of the bottom one then ya need to pull it back and arond the bottom one and all will be well. . NOW A NOTE OF caution here the top one has heavy spring pressure against it and things can be vary sharp in there .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
