Posted by mkirsch on December 11, 2014 at 05:08:11 from (72.45.143.81):
In Reply to: 12v warning light posted by bass on December 11, 2014 at 04:46:26:
Depends on which Delco alternator you use.
If you use a 1-wire alternator, you don't need the excite circuit that the light is part of. In fact there won't be any "1" or "2" terminals, only "BAT," which you hook to the ammeter.
The typical 3-wire alternator needs the light, or a diode, in the circuit to prevent the alternator from backfeeding the ignition coil with the switch turned off, preventing the tractor from shutting off.
You could, if you wanted, wire up a separate "excite" switch that you push after you start the tractor, to get the alternator to start charging. Some people have done that, but most prefer it to be "automatic."
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
