Re: 300U Loader Lower Speed
Posted by tractorsam on December 11, 2014 at 06:47:35 from (12.182.11.116):
In Reply to: 300U Loader Lower Speed posted by Al Wilson on December 11, 2014 at 06:33:06:
If you had a local hydraulic shop I'm sure they
could help you. You could put an adjustable
orifice in parallel with a one way check valve
between the valve and the cylinders. You could
adjust the orifice to a point that you're happy
with the drop speed and have the check valve set
to open when lifting so you don't restrict the
lifting speed. Good luck. Sam
  Upload Photo  Select Gallery Photo  Attach Serial No List
