Re: Farmall H new starter
Posted by mkirsch on December 12, 2014 at 04:54:01 from (72.45.143.81):
In Reply to: Farmall H new starter posted by RMOMN on December 11, 2014 at 19:54:42:
Your problem is the chewed teeth on the ring gear. Ideally you would replace the ring gear, but that involves splitting the tractor and removing the flywheel to cut the old ring gear off. The new ring gear is heated and dropped over the flywheel.
Sometimes you can get away with reaching in through the starter hole with a file, and knocking down the rough spots on the bad teeth.
The reason a few teeth get chewed up is because the engine tends to stop in one place every time it is shut down.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
