Re: Golw Plug Issues
Posted by jdemaris on December 12, 2014 at 10:28:26 from (70.194.3.25):
In Reply to: Golw Plug Issues posted by fergienewbee on December 11, 2014 at 15:14:18:
With a properly charged battery and glow-plugs energized-voltage AT the battery should be over 12.5 volts. Those four glow plugs and indicator, all together only draw 20 amps total.
When the engine is cranking -normal voltage should drop to 9 to 9.5 volts. That is the voltage a "12 volt" starter is designed to work at.
  Upload Photo  Select Gallery Photo  Attach Serial No List
