Re: Re: ATF as hydraulic fluid?
Posted by Alvin on January 08, 2001 at 18:08:15 from (204.246.218.81):
In Reply to: Re: ATF as hydraulic fluid? posted by Jim Becker on January 08, 2001 at 07:42:22:
ditto-- unless ATF is recomended I would not use it for hydraulic oil.
Post A Followup
: Re: Re: Re: ATF as hydraulic fluid?
