Re: Yet Another M Question
Posted by D Slater on December 12, 2014 at 18:04:33 from (184.14.166.249):
In Reply to: Yet Another M Question posted by mongo6318 on December 12, 2014 at 17:37:11:
With that weight a seat with spring under the seat, or what IH called a hydraulic seat will also go way down. You can put a air up ball inside the spring for heavy weight.
Spring pressure can be adjusted on the seat you have by screwing down the two jam nuts. If that spring breaks you just drop until the pipe hits the deck. Just want to make sure the pivot pin and parts are in good shape.
Your choice on what way to go.
  Upload Photo  Select Gallery Photo  Attach Serial No List
