Just my opinion if you have worries about the seats is to check the pivot systems on all types. Seat like yours remove the pipe and spring from the steel bracket that bolts to the top cover. If the pipe is in good condition with no cracking which sometimes happens near the pivot hole or spring bolt hole and the pivot holes are not worn much? Spring bolt and pivot pin good? Just check the seat end mounting. Have welded new pivot pin sleeves in the pipes if needed to keep seats from tilting side to side and repaired the spring bolt holes. If the tilt seat mounting is good that seat will stay on the tractor unless the spring or bolt and pivot pin fails at the same time. If the pivot system fails on the other type IH seats, the seat may hang by the shock but the operator won't be there unless hanging on the steering wheel.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
