Re: Golw Plug Issues
Posted by jdemaris on December 13, 2014 at 05:39:24 from (70.194.4.116):
In Reply to: Re: Golw Plug Issues posted by vthokieag on December 12, 2014 at 17:37:26:
Guess you have to define "fine." The original plugs are very slow, are NOT burn out proof, and if one goes bad - NONE will work.
The new upgrade plugs that Bosch makes let the engine get ready to start almost 3 times as fast. They are burn-out proof and if one DOES go bad, the other three still work. Even nicer, the new plugs don't cost much more then the original open-element low-voltage plugs.
So I guess if you say the OEMs are "finer", I guess the new plugs are "FINER."
190D Mercedes used the same glow plug system as the B414. The upgrade was made with the Mercedes cars in mind along with Unimog trucks. Work great in the IH B275s, B414s, and 3414s also.
  Upload Photo  Select Gallery Photo  Attach Serial No List
