fixerupper said: (quoted from post at 21:12:48 12/13/14)
I'm about 45 miles from a salvage that probably has one. Hy Capacity is 50 miles away but I'd probably have to find a dealer. Jim, you know more about welding than I ever will but, respectfully, I have a fear of the welding chrystalizing the shaft and possibly having a catastrophe if it breaks. I will be loading big bales starting Wednesday and I don't trust it the way it is fixed now so some kind of a good fix will be happening soon.
There was a change made to the cylinder rod and ball joint that increased the diameter of the threaded area, holds up much better.
if you get a salvage yard cylinder keep in mind that there are two different bodies used depending on whether it's an original pin style anchor or the ball joint style. The difference is in the location of the pivot on the cylinder.
I would recommend against welding the cylinder because of the potential of breakage and losing the ability to reseal the cylinder if the left side seal decided to start leaking profusely.
This post was edited by Jim Naden at 09:27:26 12/14/14.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
