Re: Little OT - Need Help with Lincoln Welder w/ Detroit Die
Posted by Jon Hagen on December 14, 2014 at 12:18:23 from (69.26.17.105):
In Reply to: Re: Little OT - Need Help with Lincoln Welder w/ Detroit Die posted by RTR on December 13, 2014 at 07:43:00:
While you have the valve cover off for repairs, check the injector control rack and injectors for free movement all the way from closed to full power.
The rack levers move the injector control rods( looks like a rod with gear teeth cut in the side, sticking out of the side of the injector.). The most common reason for runaway of a Detroit diesel that has set unused for a while, is rust sticking an injector in the wide open position. Full travel on those control rods is from almost touching the injector body when closed, to extending out about 2 inches when in the wide open position. The rack must move smoothly with no sticking.
  Upload Photo  Select Gallery Photo  Attach Serial No List
