If your going to try and replace the front seal. you need to pull the front end. There is no room to get tools in, or get the parts (crank pulley, timing gear cover, ect) off. If you have a hoist or loader tractor you can take the rad/ front end/axle off as an assembly. Drain the coolant; disconnect power steering lines(under frame rail), radiator hoses, and hydraulic cooler lines. Be sure to mark the Hyd. cooler lines there's a check valve on one of the lines. Block up engine/back of tractor remove 4 bolts each side and slide out front end. (for ones with wide fount there are also 3 bolts underneath that hold the yoke ball)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
