Re: update on 706 bought at a sale
Posted by John A on December 14, 2014 at 16:52:10 from (162.251.9.41):
In Reply to: update on 706 bought at a sale posted by Central Illinois on December 14, 2014 at 09:36:20:
Central Ill., If You are going to do anything all take 1 hr and drop the Pan. Gingerly tap on the pan to break it loose, Perhaps the gasket will stay in one Piece.
Wash out the pan, Oil Pump and Screen! See it there is anything obviously, metal in the bottom of the pan, "the 2 inches of black cream cheese" in the bottom of the pan, Sludge build up, Metal filings! In general inspect the bottom end.
Them reinstall the pan, if all looks as good as you think!
Centex Farmall put Me on to this little trick, & I am a sold-out Believer as a First step in getting and older engine going that has been neglected, abandoned, Left for dead! for most any extended period of time!
Before you pop the Head off, Run a Compression check Just to Know!! First dry, Second, wet w/ oil! Hope this helps!
Later,
John A.
  Upload Photo  Select Gallery Photo  Attach Serial No List
