Re: Impeller&shaft and dissasembly help MODEL H WATER PU
Posted by djsamuraii on December 15, 2014 at 14:36:17 from (199.27.156.4):
In Reply to: Impeller&shaft and dissasembly help MODEL H WATER PUMP posted by rustyfarmall on December 15, 2014 at 14:24:29:
rustyfarmall said: (quoted from post at 15:24:29 12/15/14)
Might be a better bargain to just buy the complete new pump.
https://www.yesterdaystractors.com/Farmall-H_Water-Pump_54148DA.html
I would if I could. My H runs on LP propane. So theres an extra hole in the waterpump I doubt I can find one with that hole. It was a pain in the rear as this hole has a pipe that comes up right in front of the engine bolts. Had to remove that pipe. None the less that's why Im needing to rebuild this original pump. Thanks for trying to help I didn't think anyone would.... I appreciate it..
This post was edited by djsamuraii at 14:39:45 12/15/14 9 times.
