Re: IH 806 Standard
Posted by dmiller on December 15, 2014 at 19:33:29 from (162.253.12.150):
In Reply to: IH 806 Standard posted by Lee A. Schexnaider on December 15, 2014 at 13:47:35:
Check the main hyd. filter, also make sure the oil level is totally full or even over full (I keep mine about 3 gallons above full).
I had problems with the power steering on mine and the mechanic diagnosed it as a plugged filter and low oil level. From my understanding there is one pump/filter and one control valve for nearly everything on an 806.
  Upload Photo  Select Gallery Photo  Attach Serial No List
