If the tractor has the additional spin on filter for the hydrostatic pump check to make sure no one has used jumper cables to start the tractor and accidentally made contact between the battery cable and the filter. That can burn a small hole in the filter where it is hard to see and allow air into the hydro charge pump. When that happens the tractor will not move.
If the hydrostatic pump is putting the air in the system the other hydraulics nay work a short period of time when first started after sitting overnight.
The oil should be clear enough to clearly see the dip stick through the oil. The oil level should drop between 1 1/2 to 3 inches after running three minutes after a cold start.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
