Re: Weak spark on Cub Lowboy
Posted by old on December 16, 2014 at 10:43:57 from (209.86.226.34):
In Reply to: Weak spark on Cub Lowboy posted by Richard G. on December 16, 2014 at 07:54:17:
+ ground means + to the points. As for spark if it is in fact a true 12 volt coil yes spark would be weak on a 6 volt battery but unless he or some one else replaced the coil it is likely to be 6 volt coil. Try putting the old condenser back in. Now days it is common to get a new bad condenser. Also make sure the points are set to the correct gap
  Upload Photo  Select Gallery Photo  Attach Serial No List
