they are generally on a riveted plate, somewhere in the door jam. there may be a second vin stamped into the firewall just behind the engine or under the cowl top panel around the wipers. there is also a vin stamped into the frame, usually around the transmission crossmember. if you cannot locate a vin, depending on the state you live in, the secretary of state police division of motor vehicles can send someone out and they will locate the vin, often times they can put an assigned vin tag on the vehicle proving the state verified the serial number. check at your dmv. or if you have a local body shop that rebuilds totals, they may be able to steer you in the right direction.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
