Re: Diesel Oil Pressure
Posted by T_Bone on January 09, 2001 at 03:00:17 from (207.254.53.61):
In Reply to: Diesel Oil Pressure posted by brian on January 08, 2001 at 06:30:15:
Hi Brian, Oil pressure has to do with alot of items. Example, The spec in the manual is for pressure with the recomended oil weight 30w, at 70f abiment temp with engine running at 180f coolant temp at 1500rpm = 70psi oil pressure. Change any one of the above and the oil pressure will be different and I'm not quoting any pictular spec either. A every day tractor mounted gauge will not be as accurate as a Stewart Warner oil pressure gauge that is used for nothing but testing. Oil pressure is also different for every engine. To say that 45psi is correct for every engine would not be correct but would be a close enough reading to not to worry about it.
I did buy a 75 psi IH "logo" oil pressure gauge at Buckeye Tractor recently.
T_Bone
Post A Followup
: Re: Re: Diesel Oil Pressure
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
