Re: Weak spark on Cub Lowboy
Posted by John T on December 16, 2014 at 11:50:45 from (216.249.72.121):
In Reply to: Weak spark on Cub Lowboy posted by Richard G. on December 16, 2014 at 07:54:17:
"If it is 12, would that make the spark weak on a 6 volt system?"
YES If you apply 6 volts to a 12 volt coil the spark will be weak
"Also, on a positive ground system, does the hot wire from the switch go to the + or - on the coil?"
Input from ignition switch to - coil terminal and + of coil to ground (via closed distributor points) for a Pos ground tractor.
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
