Re: IH 806 Standard
Posted by Cory Schmidt on December 16, 2014 at 12:43:54 from (64.246.253.39):
In Reply to: IH 806 Standard posted by Lee A. Schexnaider on December 15, 2014 at 13:47:35:
What I know about a 806 is that it is basically the same as a 706 just more horse, ect. With that in mind and what I know about 706's (from working with/on the one on the farm) there are two(or more) hydraulic pumps on it. One pump for breaks, steering, T/A. The other for 3point and remotes. The HY-TRAN fluid circulates through all systems and one main filter. Start with check/change of filter and level. If that is good I am guessing you could try to check over the steering valves
This post was edited by Cory Schmidt at 14:12:18 12/16/14.
  Upload Photo  Select Gallery Photo  Attach Serial No List
