Re: Impeller&shaft and dissasembly help MODEL H WATER PU
Posted by djsamuraii on December 16, 2014 at 14:54:36 from (199.27.156.4):
In Reply to: Impeller&shaft and dissasembly help MODEL H WATER PUMP posted by tractorguy2 on December 16, 2014 at 14:49:53:
I will check with them. Hopefully they do. Like I said I found some used ones at a ridiculous rate.
